If you like me have struggled to get custom emojis to work, then this is a quick fix until they solve it permanently.
Currently, custom emojis are not aligned and there seems to be a bug that does not scale your images, and they somehow get stuck with the previous size and a bunch of other weird things.
I have solved this by adding a CSS to my theme settings and then I brute forced in SVG files rather than PNG.
This is an ugly fix, but it works, as you can see from these emojis
