4.5: Improvements for theme designers
If you've been around Invision Community for a while, you'll know our frontend default theme hasn't significantly evolved since the early days of 4.0. Indeed, the last significant refresh came with 4.2.
With the upcoming release of 4.5, we wanted to revisit the default theme and give it a facelift for 2020, as well as make incremental improvements to the underlying codebase as a stepping stone to a bigger re-engineering in a future version. Keep an eye out for our next blog for more on the facelift.
In this entry, I want to go over some of the design and code-level changes we've implemented that will be of particular interest to third-party theme designers, or those building a custom theme for their community.
IE11 Support
Until now, we've supported IE11 as a 'B' browser - meaning we didn't aim for perfect support (especially visually), but did aim to make all functionality work, and we fixed IE11-specific issues if possible.
As of 4.5, we no longer support IE11 in any way and Invision Community will not work well in that browser. By removing support for IE11, we are able to make use of newer CSS technologies which significantly eases development for us and third-party designers. I'll discuss some of those below.
Combined theme settings
We've combined a number of existing theme settings into one new setting. We've found that settings like poll_bar, step_background, rating_hover and so on are nearly always set to the same color - typically the site's main brand color. These settings have therefore been replaced with one new brand_color setting, which is used throughout the CSS in places where this primary color would be needed. This will simplify the early stages of theme development and make it easier to match branding in Invision Community.
Front end colors
Removing hardcoded colors
While our theme settings have allowed community owners to change most colors, there were still many hardcoded in our CSS framework. These were typically neutral colors used for things like 'close' links, semi-transparent backgrounds and so on, but it was enough to make creating a dark theme an unrealistic prospect without an awful lot of effort (and kudos to those designers who have offered dark themes up until now!).
In 4.5, we've removed hardcoded colors from our framework, and instead rely on colors already defined by theme settings. You can now, finally, create a dark theme just by editing the built-in theme settings.
Type scale & {fontsize} tag
While we've had fixed type-size classes (e.g. ipsType_normal) for a long time, in practice many elements had their own font sizes set. This leads to inconsistency and poor visual rhythm too. Another side effect is it was also tough to globally change the font size (such as for branding purposes, or to create a theme for visually-impaired users).
To solve these problems, we first created a type scale; that is, a fixed number of sizes to choose from. A product the size of Invision Community does have need for a flexibility, so we settled on the following scale:
x_small: 12; small: 13; medium: 14; base: 16; large: 18; x_large: 20; 2x_large: 24; 3x_large: 30; 4x_large: 36.
All of these values are editable as theme settings, so each theme can adjust the type scale used. Our default CSS in 4.5 has been fully updated to put all type on this scale.
To actually make use of these settings, we have added a new {fontsize} tag which accepts either a scale key, or a specific pixel size (for those occasional situations where a specific size is absolutely needed, e.g. icons).
Why couldn't we just use {theme="x_small"}, or even CSS variables? To solve the problem of globally scaling text, we have also added a percentage-based scale setting that will save you from having to create your own type scale. The {fontsize} tag automatically applies the global scale to any values passed into it. Want text in your theme to be twice as big as default? Simply set the global type scale to 200% and the entire theme will reflect the change immediately.
The new font size options
Spacing scale
The lack of a consistent spacing scale has led to some arbitrary values being used in any given situation, which again has had a negative impact on the visual harmony of our design. We've therefore implemented a 4px spacing scale (using CSS variables rather than theme settings this time) and applied across almost all padding/margin values. In time, we anticipate fully switching all measurement values to the scale.
New CSS class families
We have added a range of new spacing classes for padding and margins, allowing far more control over how these are applied, especially on different device sizes. Previously, ipsPad (15px) was simply halved on small screens - with no 'opt-out' short of adding specific CSS. We've felt this has been imprecise for some time, especially since mobile devices typically have larger screens in 2020 and don't need to be so tightly-spaced.
ipsPad_all now replaces the existing ipsPad, and does not halve itself on small screens. Instead, there's a new responsive naming convention that allows you to apply specific padding on specific device sizes:
ipsPad_all:double md:ipsPad_all sm:ipsPad_all:half
In this arbitrary example, desktop size (the default) get double padding, medium (tablets) get regular padding and small (phones) get half padding.
We've added similar classes for top, bottom, left and right padding, as well as horizontal, vertical and none (to removing all padding) shortcuts.
For margins, the old ipsSpacer_* classes have been replaced with a new ipsMargin family that work exactly the same as the padding classes above, with the same range of flexibility.
The old ipsPad/ipsSpacer classes will continue working as they did before for backwards compatibility, but should be considered deprecated from 4.5 onwards.
We've also added a whole range of new ipsFlex classes, also with responsive controls (making it easy to have horizontal layouts on desktop and vertical layouts on mobile, for example), as well as a new ipsGap utility that automatically adds spacing between elements, without requiring manual :first-child/:last-child exclusions.
CSS variables & calc()
In 4.5, thanks to IE11 support ending, we're finally making use of CSS variables and calc() to make CSS more maintainable and easier to customize. A lot of repeating or often-customized styles - such as form field styles, message colors, card styles, border radii etc. - are now created as CSS variables, allowing theme designers to easily change styling in one place. Instead of magic numbers, we either stick to our spacing scale, or use calc() to avoid hardcoded numbers.
The future
The work we've done so far is just a 'first-pass'. We'll be pressing forward with modernization throughout the 4.5.* series and beyond with a view to reducing our footprint, improving our ability to maintain our CSS and, of course, making theming easier for our customers.
code.jpg.9b412edd181528827061b2f2dd15112
INVISIONCOMMUNITY.COM
If youve been around Invision Community for a while, youll know our frontend default theme hasnt significantly evolved...
  • Replies 1
  • Views 1.1k
  • Author
This is pretty awesome!
It will require some adjustments, but it should make things a whole lot easier when working with themes. I assume it will also mean some updates will be required to the themes, so I will have my work cut out for me 🙂
