Owner Jimi Wikman Posted February 5, 2021 Owner Share Posted February 5, 2021 We are in search of an QA Engineer / Test Automation Engineer with focus on backend automation Project description: Optimization of end-to-end flows for data related to hydro and trading in order to better enable: Data-based decision making Automation of processes Analytics / forecasting Ways of working Operational environment Solution will be developed in different parallel streams/teams using slightly different tech stack but the primary languages are Java, Javascript and Python. Solution is microservices based in a cloud infrastructure. Required Profile: Extensive hands-on experience in automation of backend tests (API-tests SOAP/REST) Extensive hands-on experience in using open-source test automation tools Experience in Java and/or Python Experience of Cloud Computing, preferably AWS Experience of implementing of automated functional tests in DevOps environment Good communication skills and ability to work in a high pace with several teams Proactive, organized, confident with drive and solution-oriented mindset Capable to adapt and work with "moving targets", i.e. adaptable to change Fluent in English (Fortum's Corporate language) Good to have Experience in Javascript and GUI-tests Experience in BDD or TDD is a clear advantage Experience in Automated Performance Tests is an advantage Experience and/or knowledge of Machine Learning Experience of data-centric applications (data ingestion, ETL) Good understanding and mindset for manual testing If you are interested: please send your CV in English along with your availability, hourly rate and a short motivation. Start: MarchVaraktighet: End of June 2021 with the option for extensionArbetsort: Stockholm (remote)Typ av jobb: Frilansare View the full article Link to comment Share on other sites More sharing options...
Please sign in to comment
You will be able to leave a comment after signing in
