[Article] Building a Movies database - using plugin and some styling
4 hours ago, kodload said:
I like you post and sharing for modification thing and now I also already bought a license for seft host and now play around with that and will be learned from you often. 😉
Sounds great 🙂
I hope to see your creations soon and also to learn new things from you that I have yet to explore 🙂
A few questions, if you don't mind.
I want to use this plugin to display Movie Reviews.
The tab that says 'Similar Movies', how hard would it be to say 'My Other Reviews' and then display all reviews from the same person, with possible pagination if there are too many?
Not sure if this is just a setting in the plugin, but at the bottom, is it possible to disable showing 'Reviews' and just show 'Comments'?
The part you added directly underneath the poster image, with the star rating and shows (0 reviews), I wouldn't really need this, since I would like to disable reviews, is this relatively easy to exclude? Even better, would it be doable to add the reviewers name in that area?
Just trying to get a feel if these changes are possible, I can set it up myself,  hopefully, following what you posted as a guide, but if you are willing to accept payment for some additional help (what I listed above), hopefully we could work something out.
I appreciate your thoughts and feedback on this, thank you Jimi.
I never mind questions, I encourage them 🙂
As far as I can see in the settings you can not remove reviews. You can probably edit the templates to get that done though, but I have not tested it.
The ratings below the images you can easily remove by editing it out from the template. Adding a reviewers name should be possible. You can for example add a custom field for it if the reviewer varies.
My Other Reviews could be a bit tricky, but it should be possible. Is it for one reviewer or can there be multiple reviewers?
No need for payments, I'll help in any way I can for free 🙂
Ok thanks for confirming. I will have to figure this out.
That's good to hear. Yes, there will be different reviewers, adding a custom field sounds good.
As I said before, you are an incredible individual. I really appreciate any help you can provide. I will go ahead and purchase the plugin and start making the changes following the guide you provided. I will get back to you to see if you are able to help with some of the tweaks I stated above. Thank you Jimi. Wishing you the best in 2021.
Regarding when you mention the following:
In order to show these fields I need to use this little piece of code:
{{$fields = $movie->customFields();}}{$fields['field_1']}
I then just change the field_1 to the field I want to display. You can see what the id of your field is by hovering over the edit button in the custom fields view.
I also want to be able to add some conditions, so I only see things if the field is filled in and in order to do that I use this:
{{if $movie->customFields('field_1')}}
All that code is already listed in the code you have in the VIEW tab?
Thank you.
Another question, in the code you have listed in your VIEW tab, would I copy and replace all the code in my VIEW tab? I see stuff related to just your forum and site? Or is there only part of the code I copy and paste or replace in mine?
Thank you.
<div class="ipsRichEmbed" style="max-width: 500px;  border: 1px solid rgba(0,0,0,0.1); ">
	<div class="ipsRichEmbed_masthead ipsRichEmbed_mastheadBg ipsType_center">
		<a href="https://www.vowel.com/" rel="external nofollow" style="background-image: url( 'https://s3.amazonaws.com/com.vowel.resources/social/vowel-share-thumb.jpg' ); background-position: center; background-repeat: no-repeat; background-size: cover; height: 120px; display: block;"><img alt="vowel-share-thumb.jpg" class="ipsHide" data-loaded="true" data-src="https://s3.amazonaws.com/com.vowel.resources/social/vowel-share-thumb.jpg" src="https://jimiwikman.se/applications/core/interface/js/spacer.png" style="height: auto;"></a>
	<div style="padding: 10px;">
		<h3 class="ipsRichEmbed_itemTitle  ipsTruncate ipsTruncate_line  ipsType_blendLinks">
			<a href="https://www.vowel.com/" rel="external nofollow" style="text-decoration: none; margin-bottom: 5px;" title="Home - Vowel">Home - Vowel</a>
		</h3>
		<div class="ipsType_light">
			WWW.VOWEL.COM
Hello Jimi, you can disregard my last message, I figured it all out and have it set up. I am just dealing with a few minor issues and was hoping you can help me with 1 thing. Please let me know if you can, and I will write it out and take some screenshots. Thank you!!
      Last night I could not sleep, so I played around a bit with this idea I have had for a while to have a section for quick links to interesting blog posts or news. I realized that not only would this be fairly easy to build, but the functionality to promote, or like, things was already built and I had the code for it installed! I just need to adjust the code a bit and give it some design love and it should be good to go.
      Anyone who remember the old Digg site probably remember the many great things you could find there in the early days. While I have no ambition to reach anywhere near the same popularity, I hope that some people might find it useful at least.  With so much content, it is hard to keep up with all the great things, so this can at the very least be a nice way for me to drop in great articles that I find.
      The idea behind this setup is fairly simple. Provide a simple way to add links to specific articles or news, so content creators can get some links back to their websites. Use a simple boost button to let people vote up good content and a bury button to vote things down. Allow for the users to see things based on last added content, curated content or based on ratings.
      In short, it will be a news aggregator like the good old Digg and it's many copycats. While it will not have as many bells and whistles, I will add a few things that I have not seen before. The perhaps most interesting thing will be the connection to other databases. This will allow me to not just share links in the Stories section, but also to cross post to for example products, companies and later on people and certain add-ons like the Atlassian add-ons.
      For now, I am just playing around in Figma to see what kind of designs I can come up with. All the heavy lifting has already been done by Ralf Herrmann, an amazing IPS creator that provide some of the best plugins for Pages. His plugin SuperVote have all the features I need to build this, even if I will hack it quite a bit.
      For now, I have an idea in my mind where I will keep the same style as for other parts of the website, which means that I will color each story based on category. I am also playing around a bit with RSS imports for certain sites that I want to keep tabs on. These will be added as hidden and then manually edited for now. Later on, I plan to have them be fully automatic, but I want to control them a bit first. Images, for example, will only be added if uploaded by the owner of the links, or if I have their permission.
      I will start small and then see what happens.
      While working on the components for the new About Me section, I realized that I needed a proper way for people to communicate with me. After considering the options for a while, I decided to build my own ticket system. This is fairly easy and I could have done things in several ways, but decided to use some tricks from my Task Manager to make it a little more dynamic.
      In essence, this is just a database where I have defined the setup so that you only see your own entries. As the owner, I of course see all entries, which makes it easy to work with. I have added a few fields to help sort things using filters. These fields include Status of course, type of request as this setup does not include any categories, Priority for escalation and SLA, which is just a date field I can set for due date that is then calculated to show time to completion.
      I also have a field for Assignee, even though it is a bit of an overkill for my purposes. I have added it thought for others to use that have more than one person managing the tickets.
      Database fields and Templates
      While working on this new set of templates, I realized that I probably should add some variables for dealing with the field numbers. In most cases you use template names, so it's fairly easy to manage, but in the case of adding the ability to update fields in the frontend we use field ID's instead. Since everyone has a different ID sequence, this can be a bit annoying to work with, so I am thinking I will add variables instead at the beginning of the templates. This way they will work just like CSS, so you can change one variable and it will update across the template.
      Easy creation
      This setup is nothing fancy and it is just a first iteration. I will probably build more on it as I see the need for it, but for now it will suit my need. All in all, it took about a week to complete, but that was mostly because I did not have much time to commit to it. I will still do a new form for this one, but other than that I think this one is done. It is nice because I only needed to customize two templates and the form, instead of all five templates.
      Tasks integrations
      I have a field for database relations that I will add later. Not that I think I will actually need it, but more because I want to write a guide on how to do it and also so I can use it if I want. I also want to make sure that if someone else wants to use both together, they have a way to do it out of the box.
      Onwards with About Me
      With this, I now only have to figure out how I want to set up the History part about me. I have some ideas for it that include setting up a database where each category will become a full width component, or just use blocks for it. I'll ponder on it some more in the coming weeks to see where I might land on that.
      Always moving forward 🙂
      View File Rank Icons for Invision Community
      A set of rank icon shapes.
      It is the same icon shapes used here on this site, but without symbols.
      You can download for free and use as base for your own Rank Icons.
      Enjoy!
      Submitter Jimi Wikman Submitted 06/26/2021 Category Design
      Enjoy!
      My assignment was to create a new design for a political community called TheLeft. The design would then be implemented using HTML and CSS. The community also needed custom content blocks using Invision Communities Pages module. I created a new structure for that and added blocks for hero banners and other blocks need to create the desired design. I also configured Invision Community and built the structure of information to make it a complete community experience.
