You will be part of a multidisciplinary team and work together to increase confidence on the product quality
You will perform manual testing on embedded systems
You will define test methods and create test cases
You will help out optimising QA processes by automating prioritised tests
You will design test scripts and plan handling of regression tests
You will design and develop compatibility tests against different mobile platforms
Who you are:
You have at least 2 years of work experience in software development as a tester, ideally on IoT products. You have tested mobile devices.
You have experience implementing quality improvements in an agile development environment
You have experience in testing OTA SW updates
You have experience in test automation, either scripting in python or similar, or in other areas such as javascript tests or automation with C++
It is not a must but it is a plus if you also have experience in testing radio connectivity
You have an agile mindset, you are fast to adapt to constant changes and you feel comfortable with it. Therefore you are a person who is aware of the project priorities and you plan your work and deliver accordingly.
You are good at communicating and reaching out both, within and outside the team. You enjoy working with others, coaching, and finding new ways to work more efficiently
You are driven and proactive
CV in English
Start: 2020-06-01 Varaktighet: 2020-08-31 Arbetsort: Stockholm, Sweden Typ av jobb: Frilansare
We are now looking for a QA consultant.
What you’ll do:
Who you are:
CV in English
Start: 2020-06-01
View the full article
