Posted December 22, 2024Dec 22 Owner We're adding a new trigger to Confluence automation that will let you run a rule when a new issue is created in a specified Jira project.Space and product admins can build a rule by navigating to a page and selecting the Automation (lightning bolt) icon.Select Issue created in Jira as your trigger.Select Connect to connect Confluence to your Jira project.If your organization has multiple Jira sites, you will need to select a Jira site from the Create connection menu.Select one or more projects from the dropdown menu.Continue to build your ru View full product update
