The new table layout in Product updates allows you to view more release notes on one page.
Filter by Status, Change type, or Product to get an overview of the changes most important to you, in the order they’re rolling out, so you can plan more efficiently.
How to keep up with Atlassian changes
To find and view release notes:
Go to admin.atlassian.com. Select your organization if you have more than one.
Select Products > Product updates.
